ehickey
UPDATE - Dealing with Out-of-Round?
I am still somewhat new (about a year) to penturning, but I am having some problems with out-of-round turnings. I have a pretty decent Delta Midi lathe, and I have eliminated everything in between but a dead center and a live center. Just the blank in the middle. Maybe I'm not being consistent with placing my calipers in the same place everytime. Here's my process:
* Place the blank between centers
* Measure and zero my calipers to one piece of hardware where one edge of wood will meet it
* Turn down and measure every once in a while
* When I get close to zero, I will stop the lathe, measure, rotate the blank 1 quarter turn, and remeasure. At this point the two measurements will be different by about 5 thou (give or take)
I used to use a mandrel, but stopped thinking it was the problem. I was still using bushings though. Now I've stopped using bushings thinking they were the problem. Now I just don't know. Inconsistency in caliper placement doesn't account for everything, because when the pen is assembled, there are places where it is not flush and places where it is.
I've considered that maybe my tools aren't sharpened enough or correctly, which might cause me to use too much force. I do feel I push pretty hard sometimes and my skew will often "chatter" at me. Does this sound like it could be the problem?
I measured my lathe's spindel bore as best I could and it looks like it deviates by 2.5 - 3 thou. But even still, while it is on the lathe, the blank should still be round, right? Now maybe it is not concentric to the tube, but it should be round.
My final question is, am I being too particular? Is this something everyone deals with and just accepts? I look at the pictures that are posted on this site and it seems to me that the fit is typically nuts on.
Thanks in advance for your help
UPDATED CONTENT
I think that I have a resolution to my issue, thanks to everyone's help.
I believe that my problem has a couple of causes.
1) My drill press sucks...the spindle moves forward and backward a noticeable amount when it is lowered. I haven't found a solution to this yet, but it is causing a larger, and oval, hole than the one that is required. This is causing a loose fit for the tube
2) I use thick CA glue for my tubes and I don't get full coverage after the tube is inserted. This causes a void that provides no support for the wood as it gets thin.
3) My tools were super dull. I admit it...I am lazy. If my bench grinder is not out and set up, I will not use it. I work in a two car garage, and I have to stow tools as I am not using them. The dull tools were causing me to push harder than necessary, which was then allowing the unsupported wood to flex and cause out-of-round.
I think that all of these issues were resulting in out-of-round. Now, I'm sure that sharp tools will also cause a *little bit* of out-of-round, but I think that dull tools were exacerbating the problem.
I tested this with a sharp skew and a blank that was accurately drilled. I took light cuts and was able to measure that it was round with my micrometer. Whether it was off-center or not is another story
After that, I started by trying to lightly clean up an amboyna burl blank that I had been working on when all this started. My skew caught at a place where there was a void between the tube and the wood, split out, and the tiny chunk hit me square on the nose. Please don't ask why I wasn't wearing my face shield (as I rarely don't).
UPDATED CONTENT
