William Young
A while back I saw some information here about a substitute for accelerator. I didn't save the info and couldn't find it in a search.
I am doing some segmented bowl turning and experimenting with CA to glue the rings together. That uses up a lot more of that expensive accelerator than little pens do. Also, the smell of that accelerator is almost unbearable. Is there an alternative that will do the job for less money yet still work as good ? It seems to me I heard that acetone will work but then that being a solvent of CA somehow doesn't make sense to me (yet).
BTW . . . what is the normal curing time for thick CA when it is clamped between two flat 1.5" wide pieces of wood if no accelerator is used at all. ?
W.Y.
W.Y.
