The length of a log is completely up to you. What size is easiest for you to handle.
What is the diameter of the logs your handling? For 3 to 4 inch logs simply seal the ends and store. Over 4 inches split logs, and seal the ends. You can use available commercial wax emulsions Achorseal, or Greenwood Sealer. Also latex paint, canning wax, wood glue make good end sealers. Sealing the end slows down the drying process and helps prevents checking. Logs drying too fast will check & slit.
Store your logs off the ground and out of the weather & direct sunlight. I store logs in an outdoor shed, for a couple months before trying to cut them up. Some folks bring their logs into a garage or basement to dry.
Cutting green logs can really mess up saw (table, bandsaw) blades. Cleaning and wiping down equipment to prevent rust is a real pain too. Waiting a couple three months before cutting help blades cut cleaner.
Having said that couple of days after cutting, hauling, unloading, splitting, sealing, & stacking logs. Mess up my whole shop roughing out bowl blanks, or resealing blanks to dry.
