Cutting tubes - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-09-2019, 09:23 PM   #11 (permalink)
Photos: 4
Default
I cut them slightly long with my pen blank cutting jig on the bandsaw, then use a squaring jig on the sander to square the end and get to the final size. Then i use a chamfering/reaming tool I got which is used for trimming bullet casings for refillers. I also use it after squaring the blank with the sanding jig.
__________________
"If everything goes according to plan, it's a business plan, not an adventure" Bertrand Piccard
Now I realize that my shop time is high adventure.
Jolly Red is offline   Reply With Quote Top
Old 01-10-2019, 10:32 AM   #12 (permalink)
Photos: 0
Default
I use my Proxxon Mini Chop Miter Saw, it does an excellent job. I made a stop block so I can make repeated cuts without having to measure every time.
robersonjr is offline   Reply With Quote Top
Old 01-10-2019, 01:39 PM   #13 (permalink)
BKelley's Avatar
Photos: 0
Default
Like robersonjr, I use the Proxxon chop saw with the non ferrous cut off disc and I fabricated a stop that gives me the same length tube on the money each cut. I tried numerous methods, but this gives the me the fastest and dead on accuracy of any thing I’ve used.
Ben
__________________
A PROUD MEMBER OF THE GEORGIA CHAPTER IAP
BKelley is offline   Reply With Quote Top
Advertisement
Old 01-10-2019, 01:47 PM   #14 (permalink)
jttheclockman's Avatar
Photos: 83
Default
I cut on my bandsaw and clean up with disc sander. I too use the reamer Hank talks about.
Stole this photo from an older post of PenPal
http://www.penturners.org/olduploads...DSCF0007-1.JPG
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 01-10-2019, 02:25 PM   #15 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
That's it! Thanks John! Very Handy!
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 01-10-2019, 03:40 PM   #16 (permalink)
PenPal's Avatar
Photos: 2
Default
The above reamer is available from Gunshops as a cartridge reamer.
Peter.
__________________
Penpal Nil Desperandum
PenPal is offline   Reply With Quote Top
Old 01-10-2019, 04:35 PM   #17 (permalink)
More4dan's Avatar
Photos: 5
Default
I use this from Harbor Freight, about $3 to remove any burrs after cutting and sanding to length.
More4dan is offline   Reply With Quote Top
Old 01-10-2019, 06:39 PM   #18 (permalink)
mecompco's Avatar
Photos: 10
Default
Quote:
I do it this way myself, though I just make a mark and eye-ball it on the band saw. The sanding disc lets you sneak up on exactly the correct length. I use a chamfer tool from Harbor Freight.
__________________
Michael
Fairfield, Maine
mecompco is offline   Reply With Quote Top
Old 01-11-2019, 02:09 PM   #19 (permalink)
Photos: 1
Default
View in gallery
Woodpeckers Pen Mill Ci will shave unsupported brass tubing without issues. Even with a slimline, the carbide inserts completely cover and cut the ends of the tubes. No deburring required.
I've been making semi-tubeless clicker pencils (w/o center bands) by drilling a 4" long blank, then only inserting the tubes 1/2" or so on each end.
Sincerely,
Paul E. Turley
pturley is offline   Reply With Quote Top
Old 01-11-2019, 06:01 PM   #20 (permalink)
Photos: 1
Default
Metal lathe with 5C collet chuck, depth stop, parting tool. Deburring tool and fine sand paper.
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
