Cutting tubes - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-09-2019, 05:18 PM   #1 (permalink)
Photos: 0
Default Cutting tubes
What is the best way to cut tubes to length that leaves the ends looking like the came in the kit?
EG Mac is offline   Reply With Quote Top
Old 01-09-2019, 05:38 PM   #2 (permalink)
Robert Taylor's Avatar
Photos: 0
Default
I put them in a collet chuck and use the point of a sharp skew.
__________________
Bob in Ohio
"if at first you don't succeed, maybe parachuting isn't the sport for you.".
Robert Taylor is offline   Reply With Quote Top
Old 01-09-2019, 05:41 PM   #3 (permalink)
Photos: 0
Default
I use a mini plumbers tube cutter and insert the appropriate size HF punch in the tube itself.
pngeezer is offline   Reply With Quote Top
Advertisement
Old 01-09-2019, 06:54 PM   #4 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
I have used a tubing cutter to cut and a combination reamer/chamfer tool for smooth out the ends.
I cannot find that chamfer/reamer tool for sale anymore, but it might be available somewhere. I can't remember if I got it at Arizonasilhouette.com or the LittleMachineship.com
It is basically a 3 inch long bullet looking steel slug about 5/8 inches in diameter with reamer on one end and chamfer on the other end. VERY handy for cleaning up tubing end flares and crimps.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 01-09-2019, 07:35 PM   #5 (permalink)
Photos: 0
Default
I cut them a little extra long and then trim both ends with a Forster 3-in-1 Case Mouth Cutter from my reloading tools.
dogcatcher is offline   Reply With Quote Top
Old 01-09-2019, 08:11 PM   #6 (permalink)
sbwertz's Avatar
Photos: 26
Default
I use this, I keep a piece of 220 sandpaper on one of those floor glides used for moving heavy furniture...smooth on one side, rubber on the other. I put the sandpaper on the rubber side..It has a little "give" and I press and rotate the end of the tube on the sandpaper after cutting.
https://www.harborfreight.com/2-in-m...saw-62136.html
I have one at home and another at the blind center.
__________________
Sharon in Phoenix
sbwertz is offline   Reply With Quote Top
Old 01-09-2019, 08:22 PM   #7 (permalink)
Pen Joe's Avatar
Photos: 0
Default
I use what sbwertz uses, then get a 45 degree hand held reamer to trim the end inside bevel works great.
Pen Joe is offline   Reply With Quote Top
Old 01-09-2019, 08:55 PM   #8 (permalink)
sbwertz's Avatar
Photos: 26
Default
I have a t-reamer I spin in it, too.
__________________
Sharon in Phoenix
Old 01-09-2019, 08:57 PM   #9 (permalink)
Photos: 1
Default
Like dogcatcher, cutting a bit log, then trimming works great. To trim, I just use the jig for squaring the ends of the finished blank on a disk &/or belt sander. This is very controllable, and yields a nice, clean and square result.
__________________
Steve Guzy
SteveG is offline   Reply With Quote Top
Old 01-09-2019, 09:00 PM   #10 (permalink)
Photos: 0
Default
How have I never thought to put a punch inside the tube when I cut it to keep it from necking down?? Genius!!
thawkins87 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
