Cutting pre-tubed blanks
GaryT45
Avondale, AZ
I saw a blank for sale - a denim cast in clear resin with the tube cast in place - the blank is 3/4 x 5. Now that I have it in hand, I'm wondering how do I cut it - up to this point in time, I have always just glued the tubes from the pen kit into a blank and then trimmed the blank down to the tube, but here, the entire blank is a tube, which means it has to be cut to the correct lengths to start with. How have others cut these blanks to the correct lengths?
Katya
Toronto, Ontario Canada
I use the bandsaw. Be careful and make sure the blank can't rotate, as the ones I've used are not perfectly square. I use the tube from the kit to get the proper length. And you may need to tidy up the cut surface after cutting. Does that help?
StuartCovey
Rogers, AR
I've used a table saw and a bandsaw to cut mine. They both work pretty well.
And yes you will need to clean the end up with a pen mill or by sanding.
gbpens
Homer Glen, IL
Pretubed blanks will dull any type of blade. If you have several to cut use an old blade, not a new one. Any decent power saw will cut them. I have used a band saw and a cutoff saw. The band saw is safer.
