Cutting a carbon fiber blank
Florida
I bought a carbon fiber blank that is 5" long and the brass tube is installed already. Any tricks to cutting this without crushing the tube and trimming to length beside just getting as close as possible based on the kits tube?
Not knowing what you are looking to do, we can only assume things here. I assume the blank is a CF clear resin coated blank. I assume the tube that is installed is a 10mm tube. I assume you own a bandsaw with a fine tooth blade. I assume you need the full length of the blank for 2 sections of a pen. As you see too many variables untold.
I will give you some ways to cut. If you have a bandsaw with a fine tooth blade that would be the quickest way. I would make a "L" shaped sled to support both ends of the blank when cut. This will keep the blade from grabbing the blanks and possibly deforming it. You can also do this on the tablesaw with a fine tooth carbide blade. Again a sled should be used.
Another way would be to do it on the lathe and use the skew or a parting tool. This would require you be able to chuck the blank squarely. You will loose more material in the cut this way though and may not be what you can afford.
If you are still worried about crushing the tube which will not happen because it is supported and adhered to the resin. But if still worried you could always slip a dowel rod just small enoughinside the tube to support it. Don't have a dowel you say, just make one. That is what a lathe will do. Take ablock of wood and turn down to inside tube measurement.
TonyL
Georgia
I have cut them on a 10 inch fine tooth miter saw and a small proxxon saw. I did not have a problem with either. I must have made 10 of those - 8 on the large saw. I had the same concern. The dowel is a very good idea!
Florida
Thank you, I didn't mean to leave all the variables in there, sorry! I guess it's partly being new to turning, a 14 hour day at work and 8 hours drilling holes in the sky at Mach .82!
Yes, you are correct with your assumptions however I just need one piece from this blank, and only about half of it. Thanks very much for your guidance,
I appreciate it.
Florida
Thank you Tony, I appreciate it! I'll post a pic on Sunday when it's completed.
