Cutting blanks and tubes in small shop - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-22-2019, 10:42 AM   #1 (permalink)
Photos: 7
Default Cutting blanks and tubes in small shop
Hello everyone. I have a real shop up in the garage with a table saw and band saw, but I don't want to go upstairs and back downstairs each time I need to do a small cut. I'm curious to see what some of you have done in your smaller shops? Have you used anything like this? Rockwell BladeRunner Portable? I also saw the small cut off saw Harbor Freight, what about that? Just trying to see what else is out there. Thanks!
TurnKC is offline   Reply With Quote Top
Old 03-22-2019, 10:54 AM   #2 (permalink)
jttheclockman's Avatar
Photos: 104
Default
My question to you would be, what do you do when you have these pieces?? Just because you cut them, now you need a lathe or a drill press to drill the blanks. You need a lathe to turn them. I do not see the advantage of the tool you are asking about when you have a complete shop. Those type tools to me are toys. The accuracy is not there. But to make small quick cuts I am sure they will do that. To me if you have a nice complete shop I would spend the money on a tool that would benefit you in the shop. Just my opinion.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 03-22-2019, 11:52 AM   #3 (permalink)
mark james's Avatar
Photos: 498
Default
I understand your situation with a Basement Work area and a Garage work area.
I have most of my equipment in the basement, except for a large table saw and band saw. And it is certainly inconvenient to go to the garage when needed.
However, I have a small table top Byrnes Saw in the basement, so for many cuts up to 15/16" that is fine. But this is an expensive machine, and has limitations. If you have good equipment in your garage shop, I'm not sure you'll be happy with the two you linked.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Advertisement
Old 03-22-2019, 12:13 PM   #4 (permalink)
TonyL's Avatar
Photos: 6
Default
The Proxxon cuts up to an inch at 90 degrees.
https://www.amazon.com/Proxxon-37160...42847074&psc=1
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 03-22-2019, 12:22 PM   #5 (permalink)
Photos: 0
Default
For some small or single cuts I find a miter box and hand saw to be faster.
__________________
"Just because it's on the Internet doesn't make it true." - Abraham Lincoln -
Gregf is offline   Reply With Quote Top
Old 03-22-2019, 01:24 PM   #6 (permalink)
Photos: 0
Default
Band saws, table saw, RAS, sanders are all out in the unheated detached garage. If i'm only cutting one blank, i use the human powered miter box pictured below so i don't have to run outside. Kerf is a little wider than my band saw, so if it's a two-barrel pen i take the time to go out to the shop to minimize the grain pattern disruption.
earl
greenacres2 is offline   Reply With Quote Top
Old 03-30-2019, 05:32 PM   #7 (permalink)
Photos: 0
Default
I use that HF mini shop saw for any tube cutting I need to do and have had very good results.
dartman is offline   Reply With Quote Top
Old 04-01-2019, 07:21 AM   #8 (permalink)
Photos: 0
Default
For cutting tubes, I use this.
https://www.micromark.com/Miter-Box-and-Saw-Set
It would also work for small blanks and the saw kerf is very very small.
Vinglo is offline   Reply With Quote Top
Old 04-01-2019, 08:26 AM   #9 (permalink)
cozee's Avatar
Photos: 16
Default
Fortunately, my whole basement is pretty much my shop so I do not have to go far. I have the choice of several saws but currently though, I dug an old Craftsman 7" table saw out of my old "arn" stash (one of my other addictions!) that I am setting up for pen blank work only. 60t, thin kerf, carbide tipped blade and will be using a motor off of a treadmill so that I can have a variable speed saw. When i need to cut just brass tubes and cartridge casings, I use the Harbor Freight 2" mini bench top cut-off saw. Never had an issue with it.
__________________
SEMPER FI!
"The deadliest weapon in the world is a MARINE and his rifle!"
GEN. PERSHING, US.ARMY
cozee is online now   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
