William Young
I read an excellent article (and saved it) by Scott Reaves all about making custom centre bands and I made a whole bunch of them a few months ago. He suggests a 1/4" hole for them. I am finding that when I turn the blanks together with the centreband, everything looks great while the pieces are on the lathe. But when I assemble the pen, the centre bands are loose and can actually be moved slightly sideways so the band does not line up properly with the rest of the pen.
Has anyone else had the same problem ? What size drill are you using for making centre bands. Doeds it require a metric size drill ? I have a large drill index of standard drills but the only meteric ones I have are for drilling for 7 and 8 and 10 mm tubes.
I got an order yesterday from a lady that wants one each of a teak and a purpleheart and a jarrah pen with contrasting bands in a modified slimline design. I would like those bands to fit properly so I am open for suggestions before I go ahead and turn them .
Also. is it customary to glue a centreband on to a blank before drilling and turning or should the centre bands be loose and floating like in the article. ? If so, would I be right in saying it should be glued onto the centre of the upper portion of the pen ? . I would think that glueing it onto the centre of the tip end would make it hard to know how far to press in the mechanism.
W.Y.
W.Y.
