joeatact
I had some of these kits just laying around and today I thought I
would make one. Well I have made Berea European ones with no problems
but these I cannot get the twist mechanism to work. I adjust to where the point is just right but it pushes the twist mechanism way past the mark on the mechanism. The instructions says to push it in 1/4 past the line on the twist mechanism of course if you do this the thing is to far in and the drag from the tube prevents it from turning. Its the same way after I adjusted the point to where I like it. I think the lower barrel is longer then the berea and this is the difference. Any suggestions? I made the barrels to spec.
