This filigree is a "special case". Usually, you turn and allow a little for sanding to keep your OD at a nice, smooth with the fittings level.
With the filigree, the material needs to be turned to a slightly undersize diameter. Realize the wood will swell some, over time, and the filigree will not.
Just a FWIW!!
