Creeping up on that perfect fit - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 07-05-2018, 05:07 AM   #11 (permalink)
PenPal's Avatar
Photos: 2
Default
A Skew on the flate every time.
Peter.
__________________
Penpal Nil Desperandum
PenPal is offline   Reply With Quote Top
Old 07-05-2018, 05:57 AM   #12 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I have found the find sanding sponges from Harbor Freight work OK. Just need to keep a light touch. If it is real critical, I go to finer grit sandpaper. Good idea to use a piece of wood as a backer to keep the surface consistent. BTW, I'm on my second dozen of sanding sponges.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 07-05-2018, 08:33 AM   #13 (permalink)
MRDucks2's Avatar
Photos: 0
Default
At this point in my experience I also turn slightly under and build back up with the finish.
__________________
New Contest for 2019 BASH!
FINAL VOTE in what is considered the fairest, best balanced competition for all members:The PRETTY RESIN PEN CONTEST http://www.penturners.org/forum/f422...l-vote-158738/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Advertisement
Old 07-05-2018, 09:02 AM   #14 (permalink)
Photos: 1
Default
I use 1000 grit sandpaper with a very light touch. Then I use what I call the fingernail test. If my fingernail glides over the transition with out catching I stop and apply finish. It's worked every time for me and the pens always seem to come out fine (or at least no one's complained).
wolf creek knives is offline   Reply With Quote Top
Old 07-05-2018, 11:26 AM   #15 (permalink)
jttheclockman's Avatar
Photos: 84
Default
Never trust a bushing for sizing. Always use a good quality calipers. remember that if it is a wood blank that you are adding a film finish on it so you need to take that into consideration when sizing. No need to be too particular. When you get to those numbers it gets pretty much a feel thing. I am a skew user so I do my fine detailing with a tool and not sandpaper. Good luck.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 07-05-2018, 12:14 PM   #16 (permalink)
Photos: 0
Default
If I'm over, I knock the nib out, sand and refinish. Sucks to have to start over but that's what I do. I've got a nice Bloodwood Mogal I have to redo. ��
__________________
* The above post most likely has not been proof read nor grammatically correct. Spelling, ehh, 50/50 with spellcheck*
Have a Blessed Day, ivel
ivel is offline   Reply With Quote Top
Old 07-05-2018, 12:38 PM   #17 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
I have my favorite tool, my home made scraper and the experience of being able to shave a "thousands" of an inch off, or two. I don't worry if I over-turn down .005 or even .008. I just build it back up with CA, if I am going to CA the blank.
This comes with experience. By the way, HSS scrapers (as are carbide inserts) do better on hard wood and stabilized wood but if you have soft wood, skews do better. If you are doing segments, sandpaper/abranet will work but cleaning up can be a pain. With segments, the tools do a better job of making clean cuts/scrapes than sandpaper does.
Until you develop this ability, use sandpaper (or abranet) as others have mentioned, and light touches. And as JT said, use a good quality caliper.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 07-05-2018, 09:39 PM   #18 (permalink)
Photos: 37
Default
The acrylic pen I finished last week was slightly proud after micro meshing. I took it down with a fine file. I find I have better control and can hit a smaller area with a file.
__________________
Regards,
Mike
Penultimate is offline   Reply With Quote Top
Old 07-05-2018, 11:38 PM   #19 (permalink)
Photos: 0
Default
Thanks for all the responses, I should have said that I mainly do CA finishes. I am a fan of the skew and I do use it to take the CA finish down however my last attempt I also took off some timber so obviously went too far. Although I use a straight grind on my skews, I am thinking of using a curved grind ala' Alan Lacer.
Tiger is offline   Reply With Quote Top
Old 07-05-2018, 11:59 PM   #20 (permalink)
Photos: 84
Default
Quote:
Makes absolutely no difference in pen turning. You do not want to use a skew when the blanks is CAed You want to micro mesh. You will not get a great finish if you use a skew. That is to take the blank to the point a CA finish is applied and then you set the skew aside.
__________________
John T.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
