Creeping up on that perfect fit - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 07-04-2018, 09:15 PM   #1 (permalink)
Photos: 0
Default Creeping up on that perfect fit
Just wondering what others do when they are finishing a pen but you realise that you are 3 or more thousandths of an inch proud of where you want to be. Do you use sandpaper and if so what grit, making sure that you don't go too far? Do you mainly rely on a particular tool?
Tiger is offline   Reply With Quote Top
Old 07-04-2018, 09:25 PM   #2 (permalink)
thewishman's Avatar
Photos: 0
Default
Sandpaper would be a good tool. 320 or 400 would work, though it depends on the material.
__________________
Chris
Non Impedite Raditioni Cogitationis.
(Unencumbered by the thought process.)
Tom and Ray Magliozzi
thewishman is offline   Reply With Quote Top
Old 07-04-2018, 09:26 PM   #3 (permalink)
mark james's Avatar
Photos: 484
Default
Abranet - highest available. DON'T Push in, a light touch, let the mesh do it job. It will still take material off, so don't get aggressive.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Advertisement
Old 07-04-2018, 10:07 PM   #4 (permalink)
JimB's Avatar
Photos: 11
Default
Sandpaper (or abranet) is your friend when you have so little to remove. Use the finest grit you have so you don’t remove more than you want to.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 07-04-2018, 10:10 PM   #5 (permalink)
Photos: 0
Default
I have found on occasions that even though I was careful that 320/400 grit would take me too far and I have to then reapply the CA. I try higher grits like 600 to 800 and it takes too long or I'm too impatient.
Old 07-04-2018, 10:10 PM   #6 (permalink)
TonyL's Avatar
Photos: 6
Default
I leave mine over so slightly proud with a very slight radius leading to the hardware (parts). However, if too proud, I may hit it with a freshly sharpened skew or some 400 to 600 Abranet.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 07-04-2018, 10:25 PM   #7 (permalink)
Photos: 0
Default
Is there any reason why you guys suggest Abranet over conventional sandpaper? Do you find it softer? I find it doesn't seem to cut all that well.
Old 07-04-2018, 11:55 PM   #8 (permalink)
thewishman's Avatar
Photos: 0
Default
I don't care for Abranet, but lots of people do. I use Norton 3X sandpaper. Not sure what brands you have in Australia, but spending money on great sandpaper will save you a lot of trouble and money.
__________________
Chris
Old 07-05-2018, 01:27 AM   #9 (permalink)
Photos: 12
Default
When I use sandpaper (course grits for shaping) I usually use a solid piece of wood as a backer. Otherwise I tend to get an uneven surface. Some blanks are more forgiving than others. Usually I try to over turn with the skew by a couple thou and then build back up to size with CA.
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Old 07-05-2018, 03:24 AM   #10 (permalink)
Herb G's Avatar
Photos: 18
Default
Sandpaper is great for this kind of work.
Sandpaper is a tool too.
__________________
Be happy in your work...Col. Saito
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
