Carl Fisher
Well, I had an absolutely stunning piece of silver maple turned down at lunch today. It had some of the nicest figuring and sheen I've turned to date and even some natural defects I was able to fill with CA and turn into great highlights. I didn't even have to do any finish other than micro mesh the bare wood and apply some wax. Silver maple is so hard that it almost polishes like plastic.
The trouble started with a tube that grabbed too early while inserting. I had to cut it flush and glue a short piece in the other side to make up the difference. I turned it down and polished it up and went to press it all together. Put the tip into the side with the short piece of tube and it cracked the entire bottom of the blank. I was sooooooo bummed.
I saved the upper but without the matching lower, it's just not the same. Ended up slapping a walnut lower on and put it in my personal collection as an oops pen as a reminder that if you start out bad, stop and find a way to make it right and fix what you know will be wrong down the line.
