First off, this is experience only. I've not done exhaustive research.
Extremely oily woods tend to have a lot of movement in them. Someone posted a link about wood movement that I can't find right now, but I remember agreeing with the author on that.
The movement is frequently caused by heat. The heat comes from a number of sources.
The first source is in drilling and tubing the blanks. While drilling and clearing your blanks, touch the unfluted area of the bit. If it's warm, the oils in the wood are being stirred up and movement is more likely. Slow down, cool the wood. Cool the bit. I think Wayne advises using the shop vac to improve airflow. That's probably a great idea.
The next source of movement is in the use of CA. When CA cures it releases heat. More CA equates to more heat equates to more potential for movement. This is not to say that CA cannot be used on oily woods, just that there can be an added element of risk.
A third source of heat comes from turning and sanding. The potential for problems increases here. Simply using a steel tool to remove wood from the blank causes additional heat. With that heat, we have the added problem of having halted natural movement if the tubes are glued in with CA.
With all of those sources of heat and movement, it should not be surprising that additional movement during cool down or during normal day to day heat and humidity changes can further stress a blank that is only a few millimeters thick. My best thoughts are to do all you can to keep heat build up to a minimum with these very oily woods. FYI, the only pen I have had crack after assembly was a BOW pen that I had CA glued the tubes in and finished with friction polish. I was surely courting disaster! [
Among my list of "very oily" woods are cocobolo, olive wood, ebony, brazilian rosewood and a few of the other "true" rosewoods.
Shane--based on experience, do not submit a repaired pen to the PMG. Your submission is expected to be technically flawless. I've recently submitted an article to Jeff that describes my experience and suggestions. [8D]
