Originally posted by leehljp
<br />.....So, it is my theory that a rubbery glue will allow for the minute expansion/contraction without causing cracks.
Lee: I have never tried an ebony blank; but have been thinking along the same lines as you. I agree that the first thing one needs to do is select a kit where the wood shell can be turned a little thicker.
There have been suggestions by some folks that a lot of the ebony commonly available is not fully seasoned so another idea I had was to drill the blanks and then let them sit for a while so they could dry from the inside as well as the outside.
The idea of a flexible glue also occurred to me and I thought that the silicone caulk that is used on bathtubs and windows and such might be a good choice. I also thought that drilling the blank with a hole with plenty of clearance would be a plus. (Some bit recommendations produce very tight holes.) And if there was some shrinkage of the blank during drying, the hole might need to be redrilled.
And finally, Russ Fairfield posted some comments about using ebony. As I recall, he had pretty much overcome the cracking problem; but I can't, for the life of me, remember what he had to say. Maybe a search of the forum will turn up his comments?
