tinybr
can anyone tell me about this? my partner mentioned this once, and i must say im intrigued, any comments, DIRECTIONS, or antthing else that may answer a few questions i have (like arent they to soft to turn?(will they last?)) etc.
Originally posted by DocStram
<br />In addition to searching the files you can also check out the Fall, 2005 issue of Woodturning Design. There's a great article by Emory McLaughlin on turning corncob pens.
There are much safer ways to do this. I could be wrong, but I don't believe it's good practice to hold the workpiece in your hand when using a power tool, especially with your hand essentially encircling the bit. The flutes will cut you too.Originally posted by Skye
<br />I've found that the key to drilling them is to just hold the cob in your fist...
Originally posted by jeff
<br />There are much safer ways to do this. I could be wrong, but I don't believe it's good practice to hold the workpiece in your hand when using a power tool, especially with your hand essentially encircling the bit. The flutes will cut you too.Originally posted by Skye
Here's an action shot if you want to lose some sleep tonight. lol
http://www.thepenshop.net/forum/forum_posts.asp?TID=1322&PN=1
Originally posted by Glass Scratcher
<br />And he apparantly doesn't like my domain so he won't let me join!
Originally posted by gerryr
<br />You'll also get more responses if you post this under Penturning.
Originally posted by PDoug
<br />Originally posted by gerryr
OK, I'm new here and you already got me confused![] Believe me it is easy to do. But I thought this is the penturners forum, least that is what it says at the top of the display of this forum[?]
<br />Drilling a cob while holding it in your hand? Whoaaaaa .. very inadvisable to say the least. I have plenty of scars to show what happens when you get sloppy around tools.
Don't have to imagine... been there. Dried CA will do the same thing. [:0] Almost healed now. I won't be doin' that again!Originally posted by mick
<br />Heck I won't even hold a stablized corncob blsnk in my hand to use the barrel trimmer on it ...the ones that Steve White sells have very sharp edges from the poly or whatever he uses to stablize and if they spin..... well you can imagine how that would feel ...DAMHIKT! []
