corn cob pens
fernandorosa
novo hamburgo rs brasil
I am interested in exchanging knowledge on corn cob pens
Here there are some I've done
thank you
fernando
David M
Norton, Va. 24273
Also like the ones with the wood .
Most of the ones I do are on larger size kit , mostly cigars, that way there is more of the outter part showing ( not cutting into the center pith ). I coat the blank with med ca when its close to size and rub in some of the fillings / dust in the voids . Sand ond apply a few coats of med ca .After it sands smooth long way with blank , I do the thin ca finnish.
David
Old Lar
Sturgis, SD
Nice job on those corn cobs. I like the wood on the end as well. I have never done slims as the cobs that I use are too big and I run out of meat. I find they sell pretty well too.
firewhatfire
Columbiana, Alabama
When I do them as slim lines pens I use pencil cobs. They work well for smaller pens. I use the larger kits for large cobs. I also decal some of them with tractor logo's.
low_48
Peoria, IL, USA.
I use the european kits for my corn cob pens. The best cobs I have found are from a hybrid waxy corn. The cobs are white in color, but are more red after the chaff is turned off. I also experimented with dying the cob to show a better contrast. This one was a solid color dye.
http://www.penturners.org/forum/f13/dyed-corn-cob-10401/
I've also applied a dark mahogany dye, then sanded it back to show a little natural color. This accents the difference from the soft part of the cob and the kernel pockets. I had trouble with the ends blowing off when I first started. Now I take the blank off the mandrel when it is about 1/8" diameter oversize. I slide a small dowel into the tubes to be able and hold it, then saturate the cob with thin CA. I only turn with a skew, and never turn from the inside out. Always from the bushing towards the center.
ashur
Leucadia, CA, USA
The best cobs, I've found, can be gotten at the pet store. We have a PetSmart and a PetCo close that have packages of very small cobs for pet feed (Hamsters and such). I use regular inkjet ink (I suppose that any ink would do) to soak them in, then dry and turn, using CA most of the way through the process. Finely I finish the pen with a buffed out coat of CA.
I carry a throw-around pen, that I made this way about 3 years ago, in my pants pocket every day and it still looks almost like new.... except for the pen plating.
Al
