Corian Speed
andyk
Toledo, OH
What speed does everybody turn Corian at? I am getting ready to try my first Corian blank and am unsure what speed I should use.
Rmartin
Columbus, Ga, USA.
I turn everything at the highest speed my little Jet mini will go.
I also re-sharpen my tool several times while turning corian.
bruce119
Franklin, NC, USA.
Corian is easy and fun and polishes up great with no special finishes just go through the numbers wet sanding then use a plastic polish like Novus 2.
george
Ljubljana, Slovenia.
Like many other, I turn and sand at highest speed. It is so refreshing to turn something else after so many wood blanks. Just be carefull with drilling - I drill like acryril blanks (cut longer blank and cut it off after it has been drilled).
andyk
Toledo, OH
Thanks for all the suggestions! I tried one at the same speed I turn everything else which is 2900 RPM. Not the fastest on my lathe but definitely not the slowest speed either. It is a lot harder than I thought it would be...
