Considering buying a chuck - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 10-15-2017, 06:38 AM   #11 (permalink)
KenV's Avatar
Photos: 0
Default
Only one suggestion here that does not agree with my experience and measurements. I have had poor experience with the PSI Barracuda chucks. Have purchased 2 of them. One has a nasty habit of jamming. Disassembly, cleaning, measurements show that the tolerances are too loose (sloppy) on that one. The other has excessive runout compared to my other chucks.
Nova, Record, and Bulldog are excellent starting brands. Sorby and Oneway are a notch up and higher price. Top of the heap are Vicmark and Axminister Evolution chucks.
Craft Supply sells a tiny little chuck that has low runout for an attractive price that I use on theJet 1014, but it does not have "pen jaws". I do drill on the lathe with it, just not a handy.
Hard to beat the Nova G3, and it and the Record are frequently on sale.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 10-15-2017, 09:56 AM   #12 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Just another thought on chucks. If you purchase a chuck which will only fit a 1" spindle, your chuck will not be of use when you upgrade to a larger lathe.
An adapter can be used but can increase any run out.
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 10-15-2017, 11:13 AM   #13 (permalink)
Photos: 12
Default
I got the Nova G3 as my first Chuck, has done everything I have asked it to do. Also, plenty of different jaws can be purchased for almost anything. If drilling, you will need either the pen jaws or pin jaws, I bought the pin jaws for this purpose and like them. I did have to buy a 1" 8TPI adapter for my jet 1014. I assume you would need a similar adapter for the 1221.
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Advertisement
Old 10-15-2017, 12:24 PM   #14 (permalink)
WriteON's Avatar
Photos: 0
Default
Quote:
I got mine from CPO outlets....paid a few bucks for shipping. $99.99. I'm sure it can be found for the same with free shipping. This model (NOVA 48232 G3 Reversible 1 in. 8 TPI Wood Turning Chuck) fits directly on a Jet1221 or 1015. No adaptor.
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool Taig professional pool cue repair lathe....that somehow gets involved with pen blanks.
WriteON is offline   Reply With Quote Top
Old 10-15-2017, 12:24 PM   #15 (permalink)
TattooedTurner's Avatar
Photos: 250
Default
I should have mentioned that the Nova Precision is made for smaller lathes and is 1" x 8 TPI so no adaptor is needed. As you can see, there are many options and we all have our favorite setup for our lathe. Do a little homework on each chuck and go with what suits your needs in the price range you want.
Also, I've seen videos where owners of Sorby chucks say the Nova jaws can be used because the bolt pattern is the same, although I haven't verified this myself. Just something to considered since it expands your options for jaws if you go with one.
__________________
Jay
TattooedTurner is offline   Reply With Quote Top
Old 10-15-2017, 01:11 PM   #16 (permalink)
KenV's Avatar
Photos: 0
Default
I use Sorby jaws on my nova chuck. You are dead on they are interchangable.
__________________
Ken Vaughan
Old 10-15-2017, 03:52 PM   #17 (permalink)
WriteON's Avatar
Photos: 0
Default
Serrated and Dovetail jaws. Does one have a stronger advantage. I would think serrated have a little extra grip however dovetail is standard on Nova.
__________________
Current set up:
Jet 1221VS
Old 10-15-2017, 05:09 PM   #18 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Quote:
Many are going express their views for both....My preference is Dovetail Jaws. Simple and straight forward. They work well as they pull the work to the chuck as it tightens.
Some professional instructors will tell you that one needs to pay attention to the tenon for the serrated jaws. Sometimes if one tooth of the serrated jaws is on the edge of the tenon, it can push the work away from the chuck causing it not to mate tightly against the face of the jaws. A slight bevel on the end of the tenon will help with this issue.
__________________
Charlie W.
Old 10-15-2017, 07:17 PM   #19 (permalink)
WriteON's Avatar
Photos: 0
Default
I read where a Turner likes Dovetail as it does not mark up the base. That's a good point cosmetic wise. Does the tenon get dovetailed when used with serrated jaws?
__________________
Current set up:
Jet 1221VS
Old 10-15-2017, 07:57 PM   #20 (permalink)
Charlie_W's Avatar
Photos: 3
Default
The Dovetail jaws can still leave minor marking in a recess tenon. It helps if the recess is as near the size of the jaws when closed as they contact more surface than when they are expanded.
Any recess should be cut to fit the particular jaws you are using.
__________________
Charlie W.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
