bneff
Last night I was preparing a bunch of acrylic/polyresin (you know the non-wood) blanks for turning. I drilled a few with the 3/8" bit for the larger pens & then chucked up a blank (one of the Cav's pink uni blanks) for a thinner pen which needed a 7mm bit. Then the wife called and I had to run upstairs for a minute and when I got back I started drilling. About a half inch in I realized I hadn't changed drill bits. Of course the blank is too short to continue drilling and using on a larger pen.
Is it possible to cut the drilled portion off and glue/epoxy another piece on or would the seam show? Any suggestions on what I might do?
Bill
Bill
