Clip recess for Artisan Rollerball & Fountain
Russknan
Nanuet, NY
I have seen some beautiful tutorials in the library on how to make blind clip recesses. My question is a lower-tech one from a relative newbie. I've made a few of the above pens which require a small recess to be cut in the top to accommodate a part of the pen clip which gets set into it. This requires cutting through both the wood and the underlying brass tube. I've tried using a plain wood file (slow and not sufficiently accurate in my use) and a Dremel with a round diamond stone (much faster, but I tend to wobble either the holding or Dremel hand and wind up with a slot that's too wide or not quite perpendicular to the pen shaft.) I don't know whether I just need to practice more, or whether the more experienced people out there have a better way of doing it. It's a shame to produce some nicely finished and turned blanks, only to be dissatisfied with the slot at the time of assembly. Russ
azamiryou
Silver Spring, MD USA
It's hard to work accurately with a workpiece in one hand and a tool in the other. Clamp one or the other down and you'll have a lot more control. It may be enough to brace it against the workbench as you cut it - cut a small V in the edge of your benchtop, and you can hold the barrel in it so it won't slide around.
Russknan
Nanuet, NY
Thanks to all! I knew there were people out there who had solved the problem. So I've just ordered files, I'll try some woodburning, and I'll make a jig with a V. Amazing how much you can learn on this site! Russ
