NotURMailman
I had someone ask me to make them a click pen. I used this component set: Buy Click Pen Kit Gold at Woodcraft
I spent a lot of time cutting pieces and gluing up the blank. I turned it super slow to avoid blow out and took a lot of time putting a high gloss CA finish on it. Everything was good.
Then I assembled it. I used a press block and did everything by the book. But, the click doesn't work.
The only thing I could figure out was that I didn't seat the click mechanism all the way when I pushed it into the upper barrel with the refill. Has anyone else ever had this problem and do you think this is what heppened?
This isn't my first click pen, but it is my first time having this problem.
Any idea who the supplier for this kit is or where I can get a new mechanism?
Also, the upper insert that the clip goes under was a tad loose, so I used a drop of glue when I installed it. Any thoughts on how to disassemble without destroying th whole pen? (And, yes I am absolutely sure the clicker didn't get glue in or on it.)
Thanks for any help!
