:at-wits-end:
I keep running into this problem with click pens: when squaring the ends of the tubes for mounting tbc or for final squaring/remove CA prior to finishing, I end up taking off a hair too much and when the pen is put together the tip of the ink refill sticks out 1/64 - 1/32". I use a sander and jig for squaring and when I get close to the tube I let it just "kiss" the disc (barely any pressure at all). This only seems to affect the click pens as with the twists there tends to be a little bit of play in the mechanisms where the final product goes together well. I'm sure others have run into this situation, has anyone found a reliable way to deal with it (other than be extra careful)? I'm considering that for all click pens I will buy and cut my own tubes a little longer than standard so that when they are processed they will end up at the correct length. The instructions say the tubes are supposed to be 2 1/32" long, I checked them with my calipers and out of the bag they are that length. I checked my tubes prior to installing them and they came in at 1.985" so with the two together I'm short just over a 1/16th:frown:.
Anyway, any help or suggestions are appreciated.
Joe
Joe
