Yeah, boiling water will be your best friend and the steps are as follow;
Get a pot (something) big enough to get all the blanks in and plenty of room for water evaporation. Wait till the water is boiling, (do not put the blanks in until then), make sure they keep submersed in water while the wax is melting away and out.
As soon as you start seeing the way surfacing, keep scooping it out or use a paper towel to remove the wax from the water, the best way is folding the paper towel in 4 folds and then run it on the sides of the pot where must of the wax will go.
This is important as you will have no other way to know when the wax has all melted out from the wood and also stopping the floating wax to keep getting stuck to the wood again...!
When the blanks comes out of the boiling water, they "can" become very flexible, "rubbery" and will tend to bend/twist (depending on the wood types) so to void any movement, lay the boiled blanks flat tight them together with, wire, tape (both ends only), plastic zip ties, etc., and put some weight on top. This will prevent any movement of the blanks.
I don't recommend putting the blanks in the microwave to dry after being boiled, they will crack, curl, twist, and will "cook" from the inside out as the wood is saturated with water. Let them dry in a well ventilated place, if the blanks were dry (not green) when they were boiled, will only take a couple of days to air dry (depending of what sort of weather/temperatures you have...!)
Another preventive step you can take to make sure there will be good adhesion between the voids wood areas and the Alumilite or PR resins, soak the void area with thing CA, that will take care of the surfaces preparation for a successful result...!
I hope this helps, and I would be grateful if you could show a few pics between before and after, please...!
Thank you and good luck...!:wink:
Cheers
George
