Cleaning a large purpleheart slab
Woodchipper
Cleveland, TN
I scored a large piece of purpleheart, one of my favorite woods, at a local symposium; 12x12x3. It is covered in wax. I can take a cheap knife and scrap off the wax from pen blanks. However, to tackle a large piece of wood is a different story. Cut and just clean what is being used? Your help is appreciated.
keithbyrd
Mount Wolf, PA
I would still do the same thing - scrape off the wax - you can get the bulk of it off. If you are going to turn with it no big deal. I have also scraped and then ran it through my band saw or table saw just skimming the wood to clean it off
randyrls
Harrisburg, PA 17112
Scrape most of the wax off with a paint scraper. To get the last off, use 4-5 layers of paper towel and heat with an iron. Clean off the iron afterward. Use solvents to remove the wax from the iron.
Woodchipper
Cleveland, TN
Thanks. Lots to consider. I don't want to cut it all up at once. Since I'm into pens, I might just slice off enough for a few blanks. Maybe look at the grain and cut some later for some small turning projects- lidded container, perhaps?
