Jim Haslett
I started turning Classic American pens from Woodcraft. I've found that I don't particularly like the pens. However, I'm trying to get through the kits I have, but I've got a serious issue with them. None of the transmissions work properly. The transmissions extend the refill just fine, but as soon as you touch it to paper, it fully retracts on its own. I've got 2 doing this.
The first one I noticed the problem after it was complete. I'm pretty sure that one is a lost cause, as I don't know if I can get it disassembled. I tested the next one before pressing the transmission into the upper pen tube. It does the same thing. I took them both back to the Woodcraft where I got them. They let me try different transmissions from their kits in stock. We tried 4 different ones and they all did the same thing.
I was hoping to salvage at least one of these pens, as the last one I made turned out pretty good. I was able to get some shape on the bottom tube and the pen is fairly well balanced. If only you could write with it.
Has anybody else had this type of issue? Any suggestions? Has anyone disassembled one of these? Should I just toss the lot and cut my losses?
