I see alot of cigar pens made here and that includes myself. Well I ran into a problem today with a couple cigars I made. I pressed the parts together as I always do. I wanted to line up a pattern a smidegon so I went to pull the top off to reset and the center ring part came out of the tube and this happened to 2 pens. I have never had this happen before but now I am worried.
Here is my couple of questions regarding this kit or it can actually apply to all kits. Do you glue your parts in the tube with either CA glue or locktite??? Do you glue the cigar kit parts in???
Second question how do you instruct the customer to replace the insert when need be??? There is actually 2 different ways but I am now leaning to one way in particular but this will depend on the first question. I would like to hear from all you good folks first before I make a dissicion.
When you give an answer please give a reason why you do what you do. Maybe this will help others and then again maybe it is only me having the problem. Thanks.
