Cigar Pencil Kits
Randy_
Dallas suburb, Texas, USA.
I believe they use the Schmidt pencil cartridge. Far as i know the Schmidt cartridges are vert reliable so i would imagine the kits would be good too.
Dario
Austin, TX, USA.
I made a couple of CSUSA cigar pencils and I am very pleased.
Just received my order from BB and they are pretty much identical as far I can recall/tell.
Note that I haven't made any of these Berea cigar pencil kits though.
write-n-style
http://www.penturners.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=9975&SearchTerms=cigar,pencil,conversion
lwalden
Trophy Club, Texas, USA.
One thing to keep in mind, if you're making a matching pen and pencil set, the lower barrel on the pencil is slightly shorter than the lower barrel on the pen- hold the tubes up against each other and you'll see the difference. Especially if you do a matching set in the rattlesnake blanks supplied by BB, keep this in mind. Since they're already cast with the longer pen tube, you've got to take a little extra off instead of just milling down to the brass.
Originally posted by challagan
<br />Thanks guys I will give them a try!
Corey
