Go here, and poke around a bit.
http://www.joewoodworker.com/
Joe is a great guy who has posted plans on how to make your own vacuum veneering pump. Electronic cycling, or venturi type. I did make a cycling vacuum pump for veneering, and it works great....much cheaper than a commercial pump, and a fun project.
Anyways, you wouldn't really need a cycling pump for stabilizing blanks, but you can go to his site to learn how to make a vacuum pump from a compressor and a venturi valve, or just simply buy a refurbished vacuum pump like the Gast that someone linked above.
A while back, he saw a major deal on a couple hundred refurbished vacuum pumps, snagged them up, and is passing on the savings.
