redfishsc
I will find out very soon if this trick works, but I was reading Don's article on making the step drill for the Pentel pencil.
Now, I was one of the guys who bought the step way back in the group buy, like 6mos to a year ago.
Then I lost the friggin' thing[B)]...........
So, I've been putting it off b/c I don't have time during the week to go and find 1/4 steel rod to make the step-bit, and I don't keep the needed 1/4 steel rod laying around.....or do I?
Of course! A mandrel! Sure, they aren't really cheap but if you have an extra one, it's not worth the gas to go find 1/4" rod.
BY THE WAY it also happens to have the 60* cone in the end of it so a punch isn't necessary to drill the 5/32" hole dead-center to fit in the 5/32" bit. Yes, I'm using the threaded end, which makes for a strange looking drill bit but who cares?
I drilled that puppy just now, didn't even cut the mandrel short-- left it long. It drilled as straight and true as it could. It's cooling right now and I'll epoxy it together very soon. Was much easier than I thought.
We'll see how this puppy works after I head to Lowe's for the 6" long 1/4" bit.
