Charring a pen blank. - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-01-2019, 07:13 AM   #1 (permalink)
Bubba57's Avatar
Photos: 0
Default Charring a pen blank.
I'm making one of PSIs Nautical pens to add to an 'Old Spice" themed bathroom. I'm using Bali wood which looks nice but (for reasons unknown to me) I'd like to char/burn the wood. What's the best procedure for getting it sanded and finished without smearing the charred parts all over the whole pen?
Thanks in advance.
__________________
Oz never did give nothing to the pen man.
Bubba57 is offline   Reply With Quote Top
Old 03-01-2019, 08:22 AM   #2 (permalink)
Timber Ripper's Avatar
Photos: 0
Default
Do you have some scrap you can experiment with?
If so, char it and then try saturating or spraying a few coats with a sanding sealer. or CA. Light sand when dry.
I'm thinking that by sealing it first, it may prevent the char from smearing.
I haven't tried this.. Just an Idea
Timber Ripper is offline   Reply With Quote Top
Old 03-01-2019, 09:19 AM   #3 (permalink)
Charlie_W's Avatar
Photos: 3
Default
I would go with Timber Rippers advice....spray some sort of sealer first. You may try brushing with a toothbrush or nylon brush while blowing air across the piece to remove some of the loose soot but not smear it all over.
Are you going for a charred finish like a Shou Sugi Ban effect, lightly scorched, or somewhere in between? This could change the process.
Is this wood a tight grained wood or open?
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Advertisement
Old 03-01-2019, 09:37 AM   #4 (permalink)
Charlie_W's Avatar
Photos: 3
Default
This pen was created by torching some red oak, wire brushing, repeat in the process and burnished with a nylon brush. Sprayed with satin Lacquer....just enough to seal the burnt smell and give some finish but not build up and be noticeable.
Again, not sure what look you are going for but an option.
__________________
Charlie W.
Old 03-01-2019, 09:43 AM   #5 (permalink)
Bubba57's Avatar
Photos: 0
Default
Actually, that should be Beli wood, I think. It seems pretty porous / open grained. As to the kind of 'char' I want...I don't have a clue. This is total whim and I'm pretty much making it up as I go along but I like Timber Rippers advice about the sanding sealer (and also about experimenting on a scrape), and the toothbrush, I think, is a good idea. Maybe try to brush from the center towards the ends. If nothing works...well...I have more brass tubing and more wood.
Thanks, folks!
__________________
Old 03-01-2019, 09:47 AM   #6 (permalink)
Photos: 4
Default
Quote:
I never thought about making themed pens for a bathroom. Do you have a pen stand in the bathroom? Explain the concept a little further. (Not jesting, a serious question.)
Talltim is offline   Reply With Quote Top
Old 03-01-2019, 11:09 AM   #7 (permalink)
Bubba57's Avatar
Photos: 0
Default
Now, that's a pen worth looking at! I love that effect...especially the distressing, but that is further than I was going to take this one. As it turns out, though, I just got back from the shop and after playing with the scrap end decided I didn't like the effect. So, I turned it and then sanded to 320 finishing up with horizontal sanding. It had the 'rustic' look I was after so I threw a coat of BLO on it. I'll check it tomorrow and see what I think. May take a wire brush to it...may not. Definitely not going to go the CA (or Glu Boost) route. I want about the same finish look as is on yours. Thanks for sharing your work!
__________________
Old 03-01-2019, 11:10 AM   #8 (permalink)
magpens's Avatar
Photos: 76
Default
Charlie,
That pen you show is very attractive and I want to try similar.
It is clearly a closed end, but I am just wondering what kit you used ?
It looks somewhat like it might be a Zen rollerball, but the section seems different than what I have seen/used before.
Thanks.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 03-01-2019, 01:54 PM   #9 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Quote:
Originally Posted by magpens View Post
Charlie,
Thanks.
Hey Mal,
I’m not wanting to hijack Bubba’s thread but the short answer is yes, it is a Zen Kit. The cap has the clip and corners ground off and is buried deep in the wood cap. The magnetic cap still seats as it normally would. The cap covers the section completely. The section is black ebonite.
I wanted the texture of the torched wood to be counter balanced by the smooth sleek surface of the ebonite. Sort of a fountain pen look with the grip section. It ended up with a disproportionate appearance (according to some) as the cap is longer than what is considered “normal proportions” for a pen.....but I still like it!
__________________
Charlie W.
Old 03-03-2019, 01:57 PM   #10 (permalink)
Bubba57's Avatar
Photos: 0
Default
Just a whim for my own bathroom. I've got a fledgling collection of DE razors and Old Spice stuff that I'm going to decorate my bathroom with so I thought I'd go the nautical route. (BTW...my wife and I have separate bathrooms...secret to a great marriage.)
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
