skeenum
I have read where several of you use a centering bit to start holes in your blanks. What is the advantage to using a centering bit versus just using the brad point/other regular bits to center and bore the hole all the way through the blank?
How deep do you bore when boring with a centering bit? Do you under-size the hole made with the centering bit and then ream the hole with a regular bit to complete the through hole?
How much more accurate is this method?
Thank you center bit users for any information you might provide to me.
Thanks,
Thanks,
