brownsfn2
I have read many places that you can get a more accurate hole in your stock if you use a center drill first followed by the larger drill bit you are using for the tube.
I have a 60 degree center bit that is 5/16" in diameter and a norseman magnum series drill bit that is 135 degree split point drill bit. I am using the 12.5 mm for the cap of a Jr Gent II. The drill chuck I am using is the keyless chuck from PSI. Lathe speed is 1000 RPM.
I can use the center drill just fine and I drill in to just before the end of the flute on the center drill. Then I chuck up the drill bit and when I try to start drilling it shudders horribly and will not cut straight in. The hole at the beginning of the blank is larger than at the end.
I need to master this since I eventually want to do kitless and I know I need to drill accurate holes.
I have only used the drill bit 3 times so I know it is sharp and the wood I am drilling is olive wood so it is not too hard.
Am I drilling with too large of a center bit? Maybe my chuck is not accurate? I am just not sure. I am hoping someone else has had thsi problem in the past or maybe I am doing something wrong.
Thanks for any help!
