Cat's Blanks
avbill
San Bruno, CA, USA.
I have cut lenght wise a cat blank from Exotic. The lenght is 4 1/2 "
I want to make two sierra pens with it. The brass tubes are 2 1/4"
Now my question. Will there be enough of the blank after the bandsaw cut and the trimming the ends for the [2] sierra pen kits.?
thanks
Is there any tolerance in the kit for the tube and kit to work properly if it cut short by a sixteen of an inch?.
ed4copies
Local Chapter Manager
Racine, WI, USA.
On the sierra , the length is not critical.
This is NOT true of the elegant beauty, which is not a sierra, nor the click which is a special sierra. On these two, the length may be critical.
KenV
Juneau, Alaska.
You might want to consider the "cut down to Parker" click with a tube length of 1.882 inches for one of the Sierras --
Tolerance on the twist Sierra is about 1/4 inch
