Caribbean Swirl
mick
Decatur AL, USA
Bryan, I've turned several different pens using Caribbean Swirl and you'll probably need to paint the tubes a light blue color. I've done all mine this way and had no problem whatsoever. I think blackening the tubes would darken the color of the blank and change the color from the Aqua like color to a much darker blue IMHO. I turn a lot of acrylics and celluloids as well as homebrew resins and paint all my tubes a color similar to whatever the color of the blank is
TomServo
Grand Forks, ND, USA.
An alternative to paint is to get some paint tints from your hardware store and mix small amounts with some 5 minute epoxy... works well. If you have powder tints for PR, they work even better (better opacity)
terrymiller
Germany
Bryan the blackening method I use is the gun metal bluing solution. When doing this the brass will turn a silver to grey color wich may not be to dark.
