carabetec mini lathe
jbyrd24
Winston Salem, North Carolina, USA.
I have been using a carbated mini lather for quite awhile now.
When I turn antler the lathe tends to walk quite abit. I have
been looking into getting a jet lathe. I was thinking they carry
a little heavier midi lathe but can't find it. What lathe would
you folks suggest. Thanks for any suggestions.
:D
Randy_
Dallas suburb, Texas, USA.
About 10 cents worth of deck screws will solve your problem. Drive a screw through each foot into your bench. If you need to move the lathe it takes all of 30 seconds to remove the screws. I do this with my JET mini and it works just fine!!!
wdcav1952
Activities Manager Emeritus
Originally posted by jwoodwright
<br />Your problem is the carb. Sounds like a rough idle adjustment...
The Jet is fuel injected, runs much smoother than a carb...[:D][:p][}:)]
It also helps to get a can of Prop Wash and spray the carb.
[:D] [}:)] [:D]
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
Nah... I think Bryan is smart enough to make sure the deer was dead first... but don't know if he knew to take the antlers off the head first... [}:)][}:)]
