Ok, I have a good one. I know that some manufactures say to put CA glue in a jar to prevent (moisture?) from getting inside the bottle but I was told by a professional who uses and sells CA glue something different. According to this person CA glue was made to dry without the presents of air. That is why when you spill CA glue on the counter it takes much longer to dry that inside of a pen blank. He suggests that you actually leave the lid off if possible! I tried this and it worked great! I would put the lid back on at the end of the day or when I was done working and no more clogged tops or stuck lids!!!! By the time I put the lid back on the glue in the top of the tip already dripped back down into the bottle.
I have had no trouble with the thick,med or thin drying out.
It could be that I just use it before it can dry out.?
The only glue so far this DID NOT work with is the flexable CA glue. It began to get even thicker.
I would like to see what everyone else thinks.
Alice
Alice
