I gather that you are asking how to glue the tubes into the blanks.
I'm assuming you've already drilled the holes in your blanks.
I wouldn't use CA for this gluing application for two reasons: 1. The stuff's damned expensive and 2. It sets quickly.
I'd use Five Minute two part epoxy.
But some people have to do their own thing. At any rate, this method works for CA or Expoxy.
Get a potato. Punch your tube through the potatoe so that the inside of the tube is full of potatoe. You want potatoe all the way through it. This keeps the glue from getting insde the tube because the tube is full of --- you got it -- potato. As new penturners we all got glue inside our tubes at one point or another and had our tubes get stuck on the mandrel. Maybe you'll be the one person who pays attention, uses a potato, and doesn't go through this trauma.
With your potatoe in your tube, scratch up the outside of your tube with 60 grit sandpaper. This is to give more surface area for the glue to work on.
Using a bit of plastic wrap or plastic bag between your fingers and the tube, squirt out a line of adhesive on the tube and spread it all over the tube (or roll it in the two-part epoxy which you;ve mixed up on a paperplate). More plastic wrap helps here. CA will (eventually) hurt your fingers if you spread it with your bare finger.
Now comes the tricky part. Press the tube into the hole in the blank in one rapid, smooth, continuous, twisting motion.
If you're using CA and you press too slowly, the glue will set up and you won't get the tube all the way in the blank.
If you press it in part of the way and then pull it out a little ways, you'll get glue in front of the leading edge of your tube and will most likely end up with glue in your tube. This would be where you'd be grateful that I insisted on the potato.
Once the tube is in place and not sticking out of the blank at all, set the blank aside and let the adhesive set up thoroughly. Then use a pen mill (or some other method) to square up the edges of your blank, cutting just until you 'kiss' the brass of the tube.
Then mount that puppy on your lathe and turn a pen!
