CA question
Mickey
Bear, DE
Is there anything that will dissolve CA. You know, like getting it off of something you don't want it on.:rolleyes:
ldb2000
Laurence Harbor, NJ, USA.
If you are trying to get a pen apart or a part off a pen , heat works for both CA and Epoxy . Not allot of heat though or you could damage the good parts . About 150 degrees will soften the glue bond enough to disassemble most glued parts . This works great if you get a tube stuck halfway into a blank . I use a soldering iron held in the center of the tube for a few mins and the tube can be pulled right out .
Mickey
Bear, DE
You guys are going to make me tell you what I did huh? Actually it was a CA partial fingerprint where it shouldn't be. I did try the acetone and it cleaned most of it off nicely.
