montmill
I'm putting decals on wood. Once on the wood I turn the lathe by hand and apply CA to the decal making sure it's flat and covered. If I spin it on the lathe at this point I find I risk pulling the decal some.
The issue I have is after hand applying CA it's not smooth and if I try and smooth it down I cut into the decal. (wet sanding with 600 grit or micromesh)
So do you build up the CA and when you have a good thick cover on it, lightly sand and turn it smooth? Or maybe you have something else you do?
Thanks, appreciate any insight you can share.
Montmill
Montmill
