CA Glue
graham murfin
wark forest,northumberland,uk
Hi
through you fellas and the forum I've been trying CA glue to finish my pens, I bought some 151 (maybe uk only) CA glue as I already use there epoxy double cylinder its great stuff.
The CA is called as hard as nails, it makes a great job and dries straight away and comes in a good size bottle, I'ver been using it on English elm burl, boy the colour comes out nice putting 3 coats on and not sanding anymore.
But I have got what we call bog oak its oak been in peat bog for hundreds of years, I have it dried and its almost black but you still see the oak grain
I used sand and sealer its made a average job, I put the CA glue on as I did with the burl and a thick grey smoke came off the wood and turned it white:eek:
Has anyone had this experience with CA ?
GRAHAM
Drstrangefart
Woodstock, Ga. U.S.A.
Several things could have happened. The wood could have still been very moist, water sets and clouds CA. If you used accellerator, the wood could have soaked up a lot of CA and the accellerator would have made it set too fast, generating heat, and causing your problems.
mrcook4570
Mason, WV, USA.
I make quite a few bog oak pens and use CA exclusively. I also use CA as the sanding sealer. While sanding with 400 grit paper, I drizzle some thin CA on the blank. The sanding dust combined with the CA creates a slurry which fills in the open grain and leaves a smooth surface for applying CA as a finish.
It could be the CA is reacting with the cellulose in your sanding sealer. If you try the CA/sanding dust slurry, you will avoid any possibility of different chemicals reacting.
