G
Guest
Guest
I posted earlier about this and because of a typo in the original post having a typo there was a little confusion.
The lenses are plastic from lenscrafters.
They were spotted with CA glue.
I had an old pair of glasses I don't wear much any more so I tested the lenses with acteone on those.
I put some actone on a rag and wiped the lensses for a couple of minutes.
I let them dry and then washed well with water and then eyeglass cleaner,
They actually seemed cleaner than they were before I started.
I tried the same method on the glasses spotted with CA.
The glue did not dissolve immediately but did so eventually. As it did there was a film on the lenses.I continued to wipe with the acetone drenched cloth.
The glasses came clean with no noticeable damage. and they are CLEAN!
One final word.
I am due for an exam in a month or so.THe lens does have a scratch in them.
I felt that if I ruined the lenses it would not be a big loss.
It seems there was no damage, there are no blurred spots and I can see through the glasses without any problem.
If they had been new lenses I may not have tried to clean the glue off them and just gone to lenscrafters to see if they could get the glue off.
If this info helps anyone I'm glad.
I did this because right now I can't afford new glasses and I figured it was worth a shot.
Your mileage may vary proceed at your own risk.
One final word.
