mgoetz7
OK. I will start this section of the forum off with a question about a problem I have run into with CA finishes.
Every once in a while usually toward the final stages, the Micro Mesh polishing, of finishing a pen that has had 2 to 4 coats of CA applied I start seeing a small undefined area that loses the shine. It does not happen often, but almost always requires a complete sanding down and re-start of the finish.
My inclination is that it is caused by one of 2 things, 1) I have sanded through a layer of CA and the exposed one is not shining for some reason, or 2) There is something about the grain of the wood that I am not recognizing.
Anyone else experience this problem?
Mike Goetz
Mike Goetz
