Ulises Victoria
Hello.
My main problem when segmenting, especially when segmenting metal and wood, is at the drilling stage. I normally use CA to bond the materials. I know that heat softens the CA and when drilling, the heat raises to very high levels. I have had several cases of segments ungluing (degluing?) at the drilling step.
Does epoxy reacts the same to heat? Are there other alternatives that tolerate heat better than CA?
Thank you.
Thank you.
