Rifleman1776
Some days you just know you should have stood in bed. [:I] First my grass trimmer went bad, then I couldn't locate parts needed to fix. Oh, well. Better talk about penturning before List Mom gets on me. Picture below is/was supposed to be upper barrel for Baron with black titanium. It is golden desert ironwood. Not sure where I got it, probably from Arizona Silhouette as a freebie. Well, there is nothing 'iron' about this wood. It is about as ironlike as basswood and dissapointingly open grained, probably should be stabilized before use. Then this happened. Not sure why. Could bushings be worn down? Probably about two dozen uses on bushings. Shouldn't they last longer? Oh, well. Color isn't what I had hoped for either. Will glue up extra tubes in some of my osage orange and mate that to the black tn. But for now I'm going back and stand in bed. []
