hazard
Another issue:
I have been turning a few cigar pens from csusa. I am having problems removing the bushings from the tubes after finishing. I use a CA/BLO finish and then a friction polish. On the first 5 pens that I turned I was able to remove the bushing without problems but on the last two it has been very difficult. It is like the ca is getting under the tube. I end up loosing them up with pliers on each end. They are really stuck. I have one that I have to use a punch to remove it from the tube.
I was making a bloodwood cigar pen last night and when removing the bushings I accidently moved the pliers and scratched one end of the blank. Wow did the blood pressure go thru the roof. This morning I ordered another set of bushing so I can toss the current bushings at something or beat them with a hammer. I think CSUSA is really starting to like me. 3 orders in 3 weeks.
A question I have is do any of you clean your bushings to remove CA and what do you use.
Chris
Chris
