I just made the blank ( with barrel) for the PSI 2mm Mechanical pencil and discovered I did not order the bushing PKMPLBU. Is there a similar type bushing that I can substitute? Thanks Darrell Eisner
When they first put that kit into the catalog, it was listed to use the same bushings as the Stratus (PKCHPENBU). I already had those bushings, so that is what I am using. In fact, I have one ready to go on the lathe right now.
Stratus bushings are about 0.01" larger than the Mech 2mm pen, but that's probably close enough. Vertex Click & Stylus Flip Click V2 bushings are the same size as the Mech 2mm.
Thank you Carl for your reply...PSI is putting out so many kits lately its hard for me to keep track. You would think that some of them would use the same bushing.
