Stephen
Has anyone made bushes for the slimline's for mandreless turning? I am hooked on mandreless after reading this forum.
What I have in mind is to use a larger bush from some larger kits and turn the smaller end to fit the inside diameter of the 7mm tubes and the larger end to the finish size of the slimlines. In order to ensure the small end has enough meat when turned to match the inside diameter of the 7 mm tubes I was thinking of filling the inside of the bush with epoxy. Will this work? Any comments will be appreciated.
Thanks.
Stephen
Thanks.
Stephen
