Bullet Pens
melogic
Ironton, Ohio, USA.
Bryan,
Don Ward (It's_Virgil) was working on an instruction sheet or something for this at one time, if memory serves me correct. I'm not sure what the status is. Good luck!
rtparso
Carlsbad, NM, USA.
Well I have only made one so far but as far as construction is concerned I bought a piece of 5/16" (0.3125â€) OD by 0.2485"ID from McMaster-Carr. Any 30 cal is .308†but is about .310 after firing and I don’t have crimping equipment. So punch the primer out and drill the primer hole out with a 5/16†drill. BTW I recommend SPENT shells. I annealed the tube to make sure it would press nice but I am not sure it was needed. I then pressed the tube into the primer end until the tube was even with the front of the casing. I then used a large drill to dress the primer end. I found that the 30.06 is just right for a Designer and while I haven’t tried it yet I think the 308 will work also. I have not gotten a finish to work yet though. I missed the Harbor Freight sale on power coat. I am going to try Behlen Woodturner's Finish as soon as it gets here. Also for short cases like pistol rounds I have experimented with drilling out the primer hole with a drill slightly lager then the OD of a 7mm tube and slipping it on like a center band.
